Old 06-13-2015, 04:35 PM
Adam I love the hydraulics. Not sure how I missed that thread of yours if you did one. Is that a regular Saginaw style pump?
Old 06-13-2015, 08:17 PM
IHinIN IHinIN is offline
Thanks Alvy. It is an early '70s GM pump. There is a thread in the Customized Cubs section titled "Custom hydraulics on 100".
Old 06-16-2015, 10:37 PM
Finished tearing down the engine today. The rod journal on the crank is only out of spec by .0005" so I plan on just polishing it and stay with a standard rod. I haven't measured the bore yet but it has ridges worn at the top and bottom so it most likely will have to be bored.
Got a little work done on the tractor tonight. Pulled off the weights and tires, pulled out the mess of a wiring harness, and got measurements to make a guard for the left side of the tunnel to cover the lift cylinder and hoses.
Old 06-18-2015, 05:01 PM
Got a Stens overhaul kit ordered today and a guy at work has agreed to bore the cylinder for me. I would bore it but I don't have access to a machine to do it myself. Should have the engine back together in a couple weeks.
Old 06-18-2015, 05:33 PM
elshiv's Avatar
elshiv elshiv is offline
That's fantastic! Looking forward to seeing your progress
Javier~
1980ish 982 w/ 3pt. & PTO /50C deck - a Work in progress. Brinly Moldboard Plow.
I'm a complete noob at this so please take it easy on me.
Old 06-18-2015, 09:42 PM
Brent McCartney's Avatar
Brent McCartney Brent McCartney is offline
What are the hydraulic lines on the front for? Just asking
Old 06-18-2015, 10:15 PM
That's for the angle cylinder on my front blade.
Old 06-18-2015, 10:27 PM
It's now been reduced to a pile of pieces.
Next up; degreaser, then paint stripper, then sandblaster and sand paper, then primer and paint.
Still need to find a good hood since the one I have has several extra holes and a rigged up brace bolted in. Need to visit the local GT scrapyard or try to find one at the Portland show in August.
Old 06-21-2015, 06:18 PM
Got everything degreased yesterday. Today, I attacked the frame with paint stripper and got it ready to sandblast.
Pulled the axle tubes off to clean out the sludge that had collected in the tubes. While the tubes are off I drilled drain-back holes from the axle tubes into the rearend and I'm going to bore out the tubes to replace the axle bushings with needle bearings. It will also get new axle seals.
Old 06-22-2015, 12:38 PM
DirtRodHillJack DirtRodHillJack is offline
Very cool to see the work you do. I never considered adding drain back holes for the axle tubes. That's a great idea. So, the stock axles are hard enough to run with needle bearings? Or do you need to case-harden them where the bearing runs?
