Old 06-16-2015, 08:42 PM
timbo2's Avatar
timbo2 timbo2 is offline
I'm sure we'll get it figured out sooner or later.
Here is my modified lap tool used with cordless drill. The valve seats aren't loose and have no play.
- Tim
Old 06-16-2015, 09:13 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I wouldn't have a tester for the sam box, I can say those coils are prone to fail. I usually put aftermarket ones in because the kohler ones are so expensive. I have a CH25 in one of my tractors. it has 2 different brands in it. look at the intake manifold gasket to the head, I've seen those get squished out and leak causing a mis
Old 06-16-2015, 09:36 PM
timbo2's Avatar
Thanks Don,
I have gaskets on the way. Have you seen 2 different size/spec of coils like this one has?
- Tim
Old 06-23-2015, 07:35 PM
timbo2's Avatar
Update on this CH22-
I cleanup the heads, pistons and valves and got it put back together.
Here are a couple of video's. I really think it was the coil. The first video is with the old coil and the 2nd is with the new one.
I've run it quite a bit and its been great. Haven't put a load on it yet besides driving uphill but it didn't skip a beat on that.
I have a small oil leak at the breather cover plate seen in the 2nd video. Guess what was the only gasket I didn't replace? Yep the breather plate. One is on the way.
Thanks Sam Mac and all for the great help.
video 1 - Before
https://www.youtube.com/watch?v=YV9CbWHkDTI
video 2 - after matching the coils.
https://www.youtube.com/watch?v=e0t3xdQnbtQ
- Tim
Old 06-23-2015, 07:49 PM
Vid # 2 sounds way better than vid #1. Did the coil I sent to you help?
Old 06-23-2015, 08:01 PM
timbo2's Avatar
Yep Sam that's the one in the 2nd vid. Did you catch the backfire on the 1st video at the end? It kept doing that at WOT.
Thanks again-
- Tim
