Old 06-19-2015, 08:49 PM
Possible low oil?
Didja check it?
Up to 534 and counting...
Old 06-20-2015, 07:28 AM
rganva rganva is offline
yes the fluid levels are good. I need to replace the oil seals on the rear axle but that is a different issue. The battery has been tested and is good. Yes I have an ohm meter, and will be checking volts/amps. My thought was to check with those that have greater knowledge of Cub Cadets, and might know of any issues and problems with this model. 99.9% of the reply's - not going to worry about those that are less the useful.
Old 06-22-2015, 10:06 PM
just received the service manual, the ignition switch, lets just say best to spend the $26 for a new one. the wires will be interesting as they have been patched using different colors .... it might take some time but with the manual, ohm meter and patience it will get back up an running ...
Old 06-23-2015, 12:57 PM
rwairforce rwairforce is offline
Good attitude.
I'm sure you will get it running. Attitude is usually the most important part,,,than oil, gas and all that other stuff.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
