Old 07-09-2015, 02:31 PM
Air and fuel filters OK? Had an illegal come into the parts store with an air filter holding about 1 inch of crap packed on the outside, all I got out of him was"Bobcat lose power".
Old 07-09-2015, 02:33 PM
jimbob200521's Avatar
Originally Posted by Justin Witt View Post
We aren't sure about reverse because where we work is uphill. Its a mix of black smoke and white. Also, there is a (what I think it might be) a breather that goes up to the valve cover, and comes down the side of the engine, just shoots a "stream" of white smoky looking stuff. Not sure why it does that.
I'm going to let J-Mech continue diagnosing this one wanted to throw in my to see if I'm on track if this were my problem. Sounds like that's a breather hose and the "stream of white smokey looking stuff" sounds to me like there might be a gasket that's leaking antifreeze into the oil. Could also be a something with a piston allowing compression to enter areas of the engine it should. Have you checked/smelled/looked at the oil to see how it's doing?
John: How did I do for diagnosing a diesel?
-Ryan
Old 07-09-2015, 02:34 PM
Justin Witt Justin Witt is offline
Thats what the air filter on this looked like. So we replaced it. No fuel filter.
Old 07-09-2015, 02:36 PM
Justin:
Go here........ AC Forum
I am quite sure the experts there can handle this problem.
We had a diesel in with symptoms similar to what you describe and it turned out the muffler was plugged almost solid.
Pap's 100
Restored 108
1211 Dual Stick
1050
WHAT!?!?! No fuel filter?
Old 07-09-2015, 02:39 PM
Its not mine. Lets just say his mechanic doesn't know much it, so me and my friend are trying to see if we can help at all.
Old 07-09-2015, 02:40 PM
Ok we'll check that out too. Thanks Tim!
Old 07-09-2015, 02:47 PM
You just failed diesel engines 101. If you can't figure this out you need to pack up the tools and never get them out again. Good luck!
Old 07-09-2015, 02:53 PM
All right well Tim, 64fleetside, and Jim, thanks for the help guys. I'll take a look at those things and put on a filter.
