Old 07-16-2015, 12:27 PM
TheSaturnV's Avatar
Here's what I did:
• 1200º BBQ black paint on the block fins
• Head left in bare aluminum
• Aluminum bearing plate and cam cover in natural finish with clear coat
• Valve cover and throttle pivot wire brushed and clear coated
All the parts left in natural finish were done this way because they showed a high level of paint chipping when I tore it down. Also, aluminum does not hold paint all that well.
HTH
Old 07-17-2015, 09:18 PM
sawdustdad's Avatar
Originally Posted by TheSaturnV View Post
Here's what I did:
HTH
What, no chrome?
Old 07-18-2015, 04:56 AM
Originally Posted by darryljs View Post
Someone else correct me if I'm wrong, but if your engine is running hot enough to melt the paint, it's running too hot and needs adjustment (either too lean or too rich, or possibly timing). This is my opinion because my K301 didn't melt the paint on the fins.
Depends on the paint and how hard and how long you run it. It isn't necessarily too hot if it burns off paint. Some paint will burn quicker than others. I run my engines hard for long periods of time. Some only mow a little grass for an hour. SO..... there are some sorting factors.
