Old 07-19-2015, 10:18 AM
Look on Craig's list for the following 2160, 2165, 2185, LT2180 they all make great organ donors. Probably a couple others also. 16HP Vanguard or 18HP Kohler CH.
Old 07-19-2015, 10:20 AM
As an educated guess.........you have a broken connecting rod. You can tell by removing the spark plugs and rotating the engine. The broken rod will result in no pressure on the effected side when you put you finger over the spark plug hole.
Good call.
OP did you find source of the leak? New window in block?
Old 07-19-2015, 11:21 AM
KentuckyCub KentuckyCub is offline
Good call.
I couldn't find the hole, but I olny took the passenger side heat shield off. I see what looks like a small crack but can't be sure.
Really frustrating because I just spent a bunch of money and time tuning it up. Guess it was more than her old heart could handle!
Is 1811 a big upgrade?
Any opinions on new cub zero turns?
Old 07-19-2015, 11:22 AM
Thanks! I was wondering this. There are a bunch out there and didn't know what to avoid.
Old 07-19-2015, 12:05 PM
Cub ZTR...prolly not any good unless you wanna drop $8k+ on one and then I would prolly go with a Kubota or Exmark. If the box store sells it, it is garbage!
I would just find a good motor and drop in it. The 1811 is the same tractor you have with a hydro lift and nothing else. The Mags were awesome motors in their day but looks like it's time to look for a Kohler Command of a Briggs Vanguard.
Old 07-19-2015, 12:50 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Where are you in Kentucky? There is a nice 1811 on Craiglist in Middlesboro Ky.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 07-19-2015, 05:40 PM
Crestwood, pretty good haul to there.
Tags
need advice, new cub, new guy
