Old 08-10-2015, 01:28 PM
If you can't hang onto the wheel tight enough to keep it from getting ripped out of your hands, narrow tires aren't going to solve your problem. Just hang on tighter.....
Old 08-11-2015, 12:50 AM
johns cubs's Avatar
johns cubs johns cubs is offline
Anyone have any ideas on why the dozer blade would seep down with lever in neutral and engine off it there are no external leaks in system?
Fluid level is still good so there are no leaks. Any help is appreciated!
John
Old 08-11-2015, 12:52 AM
you need new O rings in the lift cylinder
Old 08-11-2015, 08:53 AM
Depends on the leak down rate, there are acceptable ones,
as in past the normal clearance in spool valve.
If it takes a day to drop, I would consider that normal, but if you can see it drop,a lift cylinder piston seal is leaking or a worn spool valve, or a combination of both.
Old 08-11-2015, 10:53 PM
johns cubs's Avatar
Yeah i can see it moving but i dont see where it is leaking. How do i get the cylinder apart to change Orings? Any body know?
John
Old 08-11-2015, 11:10 PM
cub123's Avatar
cub123 cub123 is offline
Simple, just remove the hoses out of the cylinder and the ends will pop out.
Old 08-12-2015, 02:49 AM
johns cubs's Avatar
Nice thank you for the reply! Do you know are the orings something i will have in an oring assortment pack i bought at hardware store or are they special in any way?
John
