Thanks guys!
So it seems like it is the connectors that are in the plug on the back of the ignition that are the issue. I am taking them out and bending them slightly for better contact. I did a test run after bending the one that was broken and it ran great, no issues with the pto! Your right it is the sensor 925-3251. I put the sensor back in too I guess hard to tell if functional? I ran the mower in reverse and it seemed like it cut? Does the pto actually turn off in reverse? |
![]() Quote:
The female connector has a piece of metal that folds back where the male piece fits in it broke on a number, this is what broke:
http://www.ozautoelectrics.com/media...226__55462.jpg Many female connectors dont piece of metal in the middle they just have tighter curls on the sides to hold the male connector. So i bent those in to take up the gap. Like this.... http://www.germansupply.com/home/ima...roductid=18232 Not ideal... but I dont have any of those with the extra piece of metal on hand and when it fails again I will replace, I suspect the wear was due to lack of wire support pulling on the connection. I added some zip ties to reduce strain. Thanks for all your help guys. Sean |
I could be mistaken but Gm used those before they went to weather pack connectors.
Should be delco/packard--- try auto parts/ napa or evil bay |
IH used them too. They are not hard at all to come by.
