Old 08-30-2015, 10:21 PM
timbo2's Avatar
timbo2 timbo2 is offline
Originally Posted by cub125 View Post
Sorry, I didn't realize I used the wrong coil, when I took the bad one in this is what they crossed it to.
No need to apologize, you're coil is probably fine. Some people don't communicate well here.
More than one coil can work, but not just ANY coil will work.
- Tim
Old 08-30-2015, 10:31 PM
j4c11's Avatar
j4c11 j4c11 is offline
http://www.amazon.com/Bosch-00012-Ig...ds=bosch+00012
Old 08-30-2015, 10:46 PM
The Bosch blue coil is the correct OHM coil.
That's why the pullers use it Mr. Mudpatrol. Because it is a fine replacement.
We have about 10 threads a year here where someone slaps a Chevy coil on and ends up burning points.
Once again, if you use aftermarket, make sure it is the correct OHM rating.
Old 08-30-2015, 10:48 PM
darryljs's Avatar
darryljs darryljs is offline
Napa IC14 is a 3 ohm coil, is suitable for a Cub. It has an internal resistor (no external resistor required). If you use a coil that needs an external resistor, it will have around 1.5 ohms, which will burn points and not work well.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 08-31-2015, 05:41 AM
twoton twoton is offline
Dave,
This is from Dave Kirks site;
"Here is an economical alternative to the Bosch Blue coil. The Clone Coil is made especially for us by a major U.S. manufacturer and is an exact duplicate of the Bosch coil in every respect. Featuring the same primary-to-secondary turns ratio and wire gauge, the Clone offers the same 3.2 – 3.5 ohms primary resistance and secondary voltage output and is designed for use on 12 volt systems without the need for a ballast resistor. Internally, the coil is a potted design (contains no oil) and thus is highly resistant to vibration-induced failures. The black color looks perfect on those restored tractors where an original appearance is desired. A bright-plated coil clamp is included and removable double spade connector terminals are furnished on each primary post. This coil is perfectly suited for operation with conventional breaker point ignition or for use with the PointSaver.
Clone Coil price each - $45.00 plus $11.00 Priority Mail Shipping
Found here;
http://www.kirkengines.com/#Products
It might be a bit more pricey than a NAPA coil, I don't know.
Good luck,
Dave
Old 08-31-2015, 06:08 AM
Jonathon is correct. Coils are wound with a specific resistance for the Primary Winding, as well as the Secondary Winding. To get the performance that Kohler wanted, it would be best to use the coil that was designed for their engines.
HOWEVER..........it is your tractor, your time, and your money.....do as you see fit.
Old 08-31-2015, 08:42 AM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Yep, looks like a Chevy coil but it's not. It's either a 3 or a 4 ohm coil. I can't remember.
You can get them from Primeline. Part number 4151921S.
I just ordered that part number on Amazon. I will stick with the
Kohler recommended coil
Thanks to all
Sure didnt intend to start a war about this
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 08-31-2015, 09:11 AM
At the parts store I worked, I checked the resistor coil kept in stock, was 3.6 ohms. The other coil stocked was a non resistor.
Old 08-31-2015, 09:51 AM
j4c11's Avatar
Originally Posted by twoton View Post
Dave,
"Here is an economical alternative to the Bosch Blue coil. "
Found here;
The Bosch Blue coil is $45 + free shipping on Amazon, I posted the link above. Mr. Dave Kirk fails basic math if he claims his $45+$11 shipping is an "economical alternative"
Old 08-31-2015, 12:34 PM
timbo2's Avatar
Keep in mind Amazon loses money and has every year for 20 years. A small business would have gone under 19.5 years ago with that model.
FWIW I have used Kirk, Amazon, Ebay, auto parts stores, sponsors here, and so on so I'm not being righteous
- Tim
