Old 09-02-2015, 09:27 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Well all Zach's clutch arms are longer to help with releasing the heavier spring, if Father in law goes with the 108 , he will just change spring is all
Donny
Old 09-02-2015, 12:11 PM
sawdustdad's Avatar
With a ring gear starter engine in a 108 with a QL muffler and air cleaner, a swap of the front grill assy and the hood and latch, you could make it work. check oil pan to be sure it will clear the frame. Need to look and see if the holes in the steering console sides are there for the thumb screws that hold the side panels on.
I don't think the air baffle at the back of the engine compartment is necessary.
Old 09-02-2015, 12:33 PM
It will be in a puller so all that will not matter, was trying to find out if the side shields would fit. Was told I wold have to change the bottom nose piece of the grill, thanks
Donny
Old 09-02-2015, 12:35 PM
cub123's Avatar
cub123 cub123 is offline
The air baffle let's it draw cool air from the back of the tractor rather than recirculating heated air in the engine compartment. I'll admit I've never run one without the baffle, so I can't say if it makes a big difference or not, but the idea seems reasonable.
Old 09-02-2015, 12:38 PM
This puller will have the stroud on it, so stock flywheel will circulator air
Donny
Old 09-02-2015, 12:40 PM
When we use steel flywheel with no fins, we use small fan to cool off after pull
Donny
As cub123 the baffle keeps the engine from overheating by forcing it to draw cold air from outside the engine compartment, if your building a puller that's not going to be running for long periods of time its probably not a big deal but if you plan to mow with it you need the baffle.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-03-2015, 08:56 AM
mickb72 mickb72 is offline
Default cub
Hey Donny, i know the arms are longer on the bottom. I'm talking the distance from the center of the driveshaft up to the hole for the pin in the clutch hanger. Mike
