Old 10-12-2015, 08:32 AM
Nice work, what does it weigh?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-12-2015, 10:04 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Thanks guys, it is weighing around 95 lbs at the moment. Im guessing it will weigh around 110 when finished. I think the average super gt 3pt will lift around 500 lbs. Should be able to handle this thing easy.
Essentially I have to put the cutting edge on, the center pieces for the cylinder to mount, add some gussets in a few places and its ready for testing!
Old 10-13-2015, 12:08 PM
drcjv's Avatar
drcjv drcjv is offline
Can't wait to see finished product
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 10-13-2015, 08:51 PM
Very nice! Looks like it will beat using a hand shovel and a wheel barrow.
Old 10-20-2015, 11:36 PM
Rescue11's Avatar
Did some more tonight while working on a refrigerator in the shop. Had to get a different cylinder because the other one had too much stroke. Built and welded the base brackets on the frame for the butt of the cylinder to mount on. Then drilled a hole in one of the cylinder shields to test range of motion. Im happy, now for the pix...
Old 10-21-2015, 07:33 AM
Looks great Rescue11. We will need some action pics of that too when finished. That will be a nice tool to have on a Cubbie.
Old 10-21-2015, 07:52 AM
nikster's Avatar
nikster nikster is offline
I'm impressed!
Great job.
Nik,
Old 10-24-2015, 10:42 AM
Rescue11's Avatar
Thanks guys, action pix and video are in order for sure! Trying to work on it this am without luck. Home with the fam at the moment. If i can, I plan to do more tomorrow after church.
Old 11-01-2015, 11:02 PM
Rescue11's Avatar
Well today was very productive!! Nightow1 and I finished his 3pt hitch today. If you havent checked it out yet, here is the link http://www.onlycubcadets.net/forum/s...=31710&page=12
While he finished assembly of his 782, I got quite a ways on the R-Bucket. Getting very close, in fact I would venture to say 4 more hours and its ready for a test run. Want to make sure everything will hold up before it goes to paint.
1- 1200 in pieces
1- 1864 in pieces
Old 11-01-2015, 11:05 PM
Nightow1 Nightow1 is offline
Im sure it will, the 782 will abuse it.....
