Old 09-07-2015, 08:36 AM
cadzag72 cadzag72 is offline
Do you know if it ever got towed? That's the #1 reason a pump would lunch itself. Sometimes they can be rebuilt, if nothing cracked. But since they are relatively plentiful and inexpensive, replacing it is probably your best option once you go through testing all the easier "could be's." Good luck!
Ian
Old 09-07-2015, 08:56 PM
KiwiUSA KiwiUSA is offline
Thanks all, I looked at the manual on how to decouple the tractor, I am tossing up whether I should do a filter/oil change or just rip into it and get the pump off, I don't want to waste a new filter and oil. I noticed today that the rear shaft on the pump was spinning but the tractor was going no where with about 1/4 throttle and half forward on control lever. As soon as I find out the problem after getting pump out I will re-post here to show you all what crapped out
Cub Cadet 1968 105 with Spring Assist & 3 point Hitch
42'' Mowing Deck
QA36 Snow Thrower
42'' Tiller
Snapper 1983 LT1100
1967 Mustang Coupe RestoMod
Old 09-08-2015, 10:01 AM
Drain the oil, if you find metal when you drain the oil then I wouldn't bother to change the oil and filter until you find out what failed and repair it. If no metal then go get a NAPA1410 or Wix51410 filter and some hydro oil from Wally world or TSC and do a change. If that doesn't get it going drain the new oil into a clean container so that you can reuse it. At this point you don't have much to lose. The fact that the shaft coming out of the back is spinning and it's making bad sounds is not a good sign.
Old 09-08-2015, 10:28 AM
sawdustdad's Avatar
A towed (?) tractor's hydro...This one locked up when the slippers got crammed against the housing and cracked the housing.
Old 09-08-2015, 01:53 PM
Would normal hydraulic oil work or does it need to be marked hydro static trans on bottle?
42'' Mowing Deck
QA36 Snow Thrower
42'' Tiller
Snapper 1983 LT1100
Old 09-08-2015, 02:19 PM
ford4150's Avatar
ford4150 ford4150 is offline
I buy mine at TSC. It's equivalent to HY-TRANS Plus (MS-1207), the recommended hydraulic fluid for IHC
http://www.tractorsupply.com/tsc/pro...ic-fluid-2-gal
Old 09-08-2015, 11:02 PM
Ok I just did a oil change and new filter and so far it seems to be all working again. I could not do a big test because it was late and the neighbors might get upset if I started to hot rod around the yard on a Cubby. The filter was damn tight to get off and I removed the back diff cover to drop the oil, there was a fair bit of jelly type stuff which seem to melt when touched, I also think the filter was half blocked from this god knows how many years of this jellied trans oil.
Big thanks to Ford4150 for steering me towards the right oil to get, I will run this for a week I think to let the new oil wash around and then maybe do another oil/filter change just to be safe, at 18 bucks for 2 gallons it's not going to break the bank.
Thanks to every one for their much appreciated advice, now I can move on to other little things to fix on it.
Here some pics of the rear end, the plate clearly shows where the level has been sitting for many years.
and the bad boy
and the next fixes needed
New seat coming this week
42'' Mowing Deck
QA36 Snow Thrower
42'' Tiller
Snapper 1983 LT1100
Old 09-08-2015, 11:15 PM
Terry C's Avatar
Terry C Terry C is offline
Glad it was an easy fix.
You should think about a hydraulic lift for your thrower and tiller
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
