Old 09-13-2015, 06:53 AM
ccpullin ccpullin is offline
I noticed it has the wrong hanger bracket on it. It has the curved up for later cubs and not the straight back one. Don't know if this is making the difference but I agree with others, make a longer rod to cure.
Old 09-13-2015, 09:56 AM
athomas's Avatar
athomas athomas is offline
I agree with wrong lift bracket & wrong hanger bracket,don't see any side attatchment pins in quick attach mount slots at front of tractor,agree that longer lift rod should make it work but don't think anything to be gained by removing lift stop as it is already in the foward most position and if all else were correct pieces would not have much influence on blade dropping below grade level. Looks to be an assortment of parts.
Old 09-13-2015, 11:08 AM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Thanks guys, I bought the plow this spring, and never having seen what a 105 setup should look like, didn't know of the issue until yesterday.
I think that that an adapter on the bracket should give me the length to let the plow lower past on the ground
Old 09-13-2015, 12:09 PM
I've seen chain used instead of a lift rod, just tossing this out for thought.
Old 09-13-2015, 12:11 PM
Terry C's Avatar
Terry C Terry C is offline
You quoted yourself?....I don't think I have ever seen that done.. Bravo!.....Reminds me of Groucho's quote, "Before I speak I have something important to say."
That's hilarious Lew quotes himself
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 09-13-2015, 12:33 PM
Funny that you mention that, I was just thinking about that...
