Much appreciated. Thanks!
A good hydraulic shop can cut the cylinder apart and repack/seal it. It will be expensive though...
My Collection - Original, 70, 100, 102, 123, 73, 147, 86, 149, 800, 1000, 1200, 1250, 1450, 1650, 1711, #1 #2 #3 carts, 59m Chipper, Brinly Planter Plows Discs Cultivators, rear IH backfill blade, 54" power angle blade & many other blades, decks, etc. plus many others that have come and gone... |
Here's where I had my hydraulic cylinder rebuilt for my swivel push blade on the 1650. We use them for everything hydraulic with our earth moving company.
They needed to cut the end off, repack and build a new shaft. Price was $236, basically brand new. (sorry, don't know all the technical terms) http://astrohydraulics.com/
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
How about this....
http://www.ebay.com/itm/CUB-CADET-HY...item35f374f53e or this.... http://www.ebay.com/itm/CUB-CADET-16...item419dc63da7 |
I understand the desire to get your lift system fixed so that it works and acts like it should, if I had one that dropped like a rock (as you have said your's does) it would probably make me a little crazy too.
Out of the 10 or so Cubs that I have with a hydraulic lift, only two (the best I can remember) will stay in the raised position fairly well. The rest creep down over time, some worse than others, but never-the-less they do creep down. They will only creep down far enough to hit the lift stop (which in my mind is not a lift stop... It's a "lower stop") and that is as far as they will go, period. On my mower tractors, the "lower stop" is set to my desired cutting height, when I pull out of the shed, I "drop the deck" and it lowers until it hits the stop and I cut grass. Here is the part about Maxwelhses case that I don't understand: Quote:
Once again, I do understand and don't discount the burning desire that comes from within to get something fixed (especially when you are about to go stir-crazy).
![]() Quote:
Or even worse, if someone says it can't be fixed ![]() |
For less than the cost of a shop rebuilding yours, you could likely just pick up a used one. They seem pretty plentiful and not too expensive.
Yes, you dont know exactly what you have that way. But they dont seem to go bad all that often (at least, thats been my experience). Some others might chime in with more insight, but Im not sure its worth paying someone to rebuild. |
My newly acquired 149 deck does sag over many hours. The lift stop can prevent this from happening.
My burning question is, if/when the day comes that I can no longer lift the deck, what am I to do? I'm not handy enough to rebuild the hydraulic lift and get into all that. Would it be possible to install a manual lift? |
![]() Quote:
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
