Old 10-11-2015, 11:46 PM
bocephus1991's Avatar
I'm no wiring expert, so I'll leave that to others. The engine surging I'd start with flushing the fuel system and some fresh gas. Then go from there.
Brian
Old 10-11-2015, 11:57 PM
goosegt goosegt is offline
Next time I "check" a fuse I guess I'm going to get my meter out. It was the fuse. I had a spare 10amp one for the lights and sure enough it fixed the problems....except the surge. The manual says both my fuses should be 10amp so I guess that's what I'll keep in there.
I've never had a fuse look perfect but be bad, especially a slow blow without it being melted inside.
Like I said before the last time it was surging it was a wiring issue at the voltage regulator, I was hoping that would be the case this time but those wires look good. I'll have to take a closer look at that area. Thanks for the help.
Old 10-12-2015, 06:55 AM
I have never heard of this condition. I was having a difficult time connecting the dots between an electrical issue and the engine "surging".
Old 10-12-2015, 10:03 AM
In all my searching on here I hadn't either. This spring I cleaned the carb and I checked for leaks in the intake manifold and nothing helped. Then I noticed the melted wire again. I soldered new wires and terminals and that solved the surging that time.
This time the surging is something different so I'll have to figure it out. I did order a voltage regulator last night so maybe I'll get lucky. There must be something wrong with it if it's melting wires.
Old 10-12-2015, 10:30 AM
Burnt wires and/or terminals are usually one of two things, or a combination thereof.
* Excessive Loads (High Amperage)
* Poor Connections (Loose or High Resistance)
I would be examining the situation once the new parts are installed.
Tags
982, pto, surging
