[QUOTE=drglinski;349252]Mowing is all but done here. I'm moving more leaves than I am cutting the grass under neath.
I added a rubber strip to the bottom of my snow blade so it'll get right down to the driveway. I have to mount weights, a rear light, change oil (to a lighter weight) and fart around with chains. One of them last year was not tight enough.[/QUOTE] Nothing worse than a loose fart. ![]()
[QUOTE=Sam Mac;349254]
-Ryan
Mines gonna start soon as I get my 1211 back from my brother! Lol he borrowed it a few months back until he bought a zero turn. Wanna paint it, but the thought of using a manual lift on the 1200 is changing my mind. Gonna load the tires with washer fluid and change the oil.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
When it's closer to snow season, the manual lift 125 with the mower deck gets moved behind the 125 with hydraulic lift that is ready to go with chains, loaded tires and the QA-42 .
I love having two cubs
I got plenty of firewood, tanks fulla propane for shop heat, wood
Hauling trailer has new Chinese tires that should make it thru winter, got a blade this year if we get it piled up like last February. |
Put all the cubs, Deere's and fords in the storage unit, and just put the two plows on both my pickups, job done.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
Start On are prep pick up the granden hose . Remove the mower deck put snow blower on the 1572 . Got the snow plow on for the truck out .
All I have to do, is put the rear blade on the 982. We probably won't get any snow though.
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
Thanks for reminding me :/ i still need to swap tearends in my 127. Get the blower mounted. Put a pto on it. Fix the jackshaft on the blower plus get the deck off the 102. Put the blade on. Fab up a new lift rod. And get chains and weights mounted on both :/
