Old 04-30-2010, 12:52 PM
Turbo Archie's Avatar
Turbo Archie Turbo Archie is offline
You can do it in MS paint.
Open the picture in paint, under Image/stretch-skew just make it 50%..
Old 04-30-2010, 12:56 PM
CMA's129's Avatar
CMA's129 CMA's129 is offline
I have the photos in a folder just under my windows pictures the only editing it seems to let me do is to make them bigger or crop them. but I took the pictures full frame so when I crop them down you end up with just a peice of a photo. I will try to edit them with this nikon program. If that does not work I will try your suggestion. Thanks for the help.
Old 04-30-2010, 01:06 PM
CMA's129's Avatar
I tryed doing it with paint but this is what I came up with, I had a full frame photo of my tiller pullys to try and explain what my issue is here. Well I shrunk it down so it would upload and I ended up with a full frame photo of a set screw that holds the pully on. Got to go back to work now I will try again later. Thanks again
Old 04-30-2010, 04:30 PM
Sorry, your right, it won't work on .jpg files.
Old 04-30-2010, 04:56 PM
CC Rider's Avatar
CC Rider CC Rider is offline
You might also try going into the Nikon's menu and changing the resolution down to maybe like 2.0 mega pixels .... if the camera has this option. Thats how I do all my upload pics.
Tom
CC's - 108, 122, (2)124, 149, 1320
Old 04-30-2010, 06:07 PM
MBounds's Avatar
MBounds MBounds is offline
CMA's129: Here is what I use. It's free and simple to use.
http://www.vso-software.fr/products/image_resizer/
1) select the photo you are interested in.
2) right click on the photo.
3) about midways of the dropdown box you will now see the VSO Resize option. Click on it. Go past all the questions and select the size you want. Resize.
4) This will put a new resized photo on your computer. This is the one you click on to upload... Works for me...
Myron B
Myron B
East Texas
Most of of the fleet:
Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with.
Old 04-30-2010, 07:37 PM
murphycc
Guest
Posts: n/a
Grain. You never want to reduce resolution.
Scott
Old 04-30-2010, 07:53 PM
MBounds's Avatar
Hmmmm, Well, here is a 320 x 200 pixels (SO76): and a 640 x 480 (Original), the two small sizes using the VSO Resizer. Photo's with same Olympus Digital Camera. If you click to enlarge, you will see the difference in photo size, not clarity.
Myron B
Myron B
East Texas
Old 04-30-2010, 10:09 PM
murphycc
Guest
Posts: n/a
Image size and resolution are not necissarily related.
A film speed of ISO 100 is a high resolution film and will reproduce a quality print. ISO 400 is a high speed film that will produce a lessor quailty low resolution print.
Digital cameras mimmick film in that 10 megapixel is a higher resolution than a 2MP, you want the 10MP for image quality.
As for digital resolution, the best way to describe is-
Two monitors, a 18" widescreen and a 42" widescreen, if the resolution of each monitor is the same the same image will appear in like quality with only one difference, size.
When you resize your are changing the image size and not the resolution. As for the 2MP image being a smaller file size, yes of coarse as it contains LESS information or in other words LESS resolution which translates to GRAIN. Again to relate this to film, there is less information in one exposure of 400 film than the same exposure of 100 film. In the case with the Nikon packing such a large files size, simply higher resolution which is more information which is a high quality image.
Scott
Old 04-30-2010, 10:38 PM
murphycc
Guest
Posts: n/a
Random images I took today. Once loaded it took me less than 5 minutes to process and paste here.
Scott
