Old 11-01-2015, 08:34 PM
Air hammer?
that's not in an average guy's tool box. I got a few of these
Old 11-01-2015, 10:11 PM
All good ideas so far, I especially agree with tightening a frozen/rusty fastener first to break it loose.
If I know in advance that I need to get a steering wheel off, I have been known to take the nut off spray the center shaft with acetone/diesel fuel (50/50 mix) put the nut back on and just snug it down a little. Then drive the tractor as usual, spraying before each use, they usually break themselves free in a couple of weeks. Not the ideal thing, but it does work.
Old 11-01-2015, 11:42 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Come Along, 5/8" NF Bolt and Nut, PB, Hammer, Insulated electrical wire...
Works everytime
1- 1200 in pieces
1- 1864 in pieces
Old 12-23-2015, 07:02 AM
ironman's Avatar
ironman ironman is offline
hi-tec werks
Old 12-23-2015, 08:59 PM
fourinchdragslicks fourinchdragslicks is offline
Iron Man has the trick. Put some wide washers on the other side of the block so you don't pull through it, soak that steering wheel nut, and this is the best shot at not destroying the steering wheel taking it off. The more soak time you give the nut the easier it comes off.
