Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 11-11-2015, 10:57 PM
SS5150's Avatar
SS5150 SS5150 is offline
Originally Posted by samckitt View Post
It goes along with pretty much every car I have ever owned. I have converted 3 of them to fuel injection & more power. Current project, 1986 Monte Carlo SS, stock has 180 hp carbed 305 5.0L, converting it to a 450ish HP 6.0L LS2.
Let's hear more about the Monte. I've got an '88 SS here, and a 383 with AFR heads and a roller cam sitting on the hoist. It needs EFI bad.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 11-12-2015, 07:14 AM
I suggest that if you guys want to talk about cars you start a thread in the general talk area.
Old 11-12-2015, 09:56 AM
samckitt samckitt is offline
Just my 2 cents but I think your just wasting your $$$ putting 28 HP in a 682. The Hydro can't use it nor can your mower deck. The 18HP SEW kit for the 682/782 is more than enough. That said it's your tractor and your $$$$.
You're right, its overkill. Kinda thinking I might look for a Super Garden Tractor to replace, would like something with power steering & 3pth hitch.
Old 11-12-2015, 11:19 AM
Small engine warehouse offers a 23hp Briggs for $1650 that would work and its new with a 3yr warranty, its listed under the cub cadet 1811.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-12-2015, 05:37 PM
18HP kit for a 682, $1400.00 with a 3 year warranty.
http://www.smallenginewarehouse.com/...tegory=1709370
Just my 2 cents but I have a 1641 with a 48" GT deck and the 16 has plenty of power. I'd guess that the 18 is over kill and anything over that is a waste of cash. Your wallet, your tractor do as you wish. I have nothing else to offer on this thread. Be Happy, Happy, Happy.
Old 12-03-2015, 08:36 AM
Will either of these be an "easy" swap into my 682? First has a tapered shaft, which I thing mine needs straight, & second has a 1.125" dia shaft & think mine needs 1.25...?
Thanks
http://www.ebay.com/itm/KOHLER-ENGIN...YAAOSwLzdWSnD9
http://www.ebay.com/itm/Kohler-Comma...IAAOSw~bFWLoFk
Old 12-03-2015, 09:50 AM
First engine won't play with the tapered shaft. Second engine should work. Your existing engine should have a 1-1/8" shaft.
Old 01-19-2016, 12:29 PM
No I still havent decided what I am goiing to do about the engine swap. How about this one, will it easily swap into the 682?
Thanks
http://www.ebay.com/itm/18hp-Kohler-...3D391347196774
Old 01-19-2016, 12:37 PM
Yep sure will. Hot set up would be to use the 1863 motor plate, muffler and drive shaft. It would be a bolt in swap. Jeff in PA can hook you up with a pump adapter for the 1863 CV shaft. That said I think the price is a little high.
Old 01-19-2016, 01:27 PM
Thanks for the reply. What do you think a good price would be? I take it the 1863 came with this motor?
