Old 12-02-2015, 11:07 AM
rdeyoe rdeyoe is offline
1811woody; ah, i see now. You have the turn brakes on the right, yes? Does look a bit crowded on that side. I had a friend with that "other" tractor brand, a 318 model that had the turn brakes on the right also. That does complicate things a bit, but then again, you do have a little extra length to work with. Is it just a single brake on the left side? Maybe you could move the turn brakes to that side and do the hydro on the right. Would take a lot more work though...
--Ryk
Old 12-02-2015, 08:35 PM
CC1450's Avatar
CC1450 CC1450 is offline
nice modification and great post thanks for sharing!
your method for making the arm that attaches to the shaft was brilliant, and was just the ticket to help me complete the controls for a dual stick spool valve setup I am working on.
-Mark
1978 1450
1976 1450
Old 12-03-2015, 11:04 AM
Thanks CC1450. Actually, the lift controls is where i got the idea. I wanted to put my lift lever on the left of the tractor. Mine is a 1975 model, and the lift lever from the spool valve was pinned to the shaft. The pin had sheared and i couldn't hardly remove the lever or shaft, plus it would've been a pain to put a pin back in it inside the tower. I saw that IH had redesigned the lever on later models to a clamping system. That's where the idea came from. Cold bending 1/4" flat stock without a torch is difficult, but can be done. I start it in a vise with a hammer, get it past 90 degrees or so, then put it in a press with a bolt at the bend and some flat stock along it to keep the gap. I'm sure an oxy torch or mini forge would make it much simpler / neater.
--Ryk
Old 12-04-2015, 03:55 PM
garrynok's Avatar
garrynok garrynok is offline
Rdeyoe, some of the foot control setups I have seen use a damper in addition to the self centering spring. The damper is suppose to keep the foot pedal from jerking when you hit a bump. I'm curious how your setup works when traveling across a bumpy yard. Do you have to fight the pedal or does it tend to stay in one place?
Garry
Old 12-08-2015, 12:57 AM
Hey garrynok. Not sure what you mean by "fighting the pedal", My foot rests on the tread plate, so i'm not bouncing on it at all. The centering spring might could be a bit stronger actually. I've found that if i "floor" it, it tends to stick that way...kinda like a cruise control on high speed. A slight tap on the back side of the pedal and it returns, slowly to center again. I think maybe cutting the spring for more return pressure may keep it from sticking, but it works great where it is too.
--Ryk
Old 12-08-2015, 02:37 AM
OldSkull's Avatar
OldSkull OldSkull is offline
It's a perfect K.I.S solution, well done sir!
I never new what I was missing until I use the hydro foot control of my "carrot head". Now every time I use my QL I wish they had the same easy to deal with system.
Gilles.
1963 100 (red)/in storage
Old 12-08-2015, 11:34 AM
ironman's Avatar
ironman ironman is offline
rdeyoe, I was pondering your arrangement with a shorter spring with an "eye bolt" on one end or the other which you could use to adjust the spring tension.
Your thoughts??
Old 12-13-2015, 11:41 PM
ironman, I think that would be a great idea. The one I saw on that loader project (can't find the link now) had an eye bolt setup for the spring tension initially, but his later post said that he found he didn't need it. I like it pretty much as it is, but i may put a bit more tension in it. For some reason, as simple as it is, I hate removing the screws on the driveshaft cover. I'm going to try and come up with a way to quick disconnect it. On aircraft we had panels held with dzus fasteners. That'd be a great way to put that and maybe the side panels on / off.
--Ryk
Old 12-14-2015, 09:22 AM
ironman's Avatar
rdeyoe, Ditto with you on those screws. How about something like this for the driveshaft cover. Called Dart Type Hollow Body Panel Clips. No tools, just pull up on the cover to remove, push them back in with your thumb to put it back on.
Old 12-14-2015, 09:30 AM
The only downfall I see to that is if it doesn't hold the cover tight it might vibrate and make noise.
Pap's 100
Restored 108
1211 Dual Stick
1050
