You could build those upper arms easy enough with a welder and grinder... just sayin
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
![]() Quote:
Thanks to all who have given me some pointers. I'll post up some pics of the thrower with the right belt and pulley as soon as my McMaster order comes in today.
-Buster 1984 CCC 680 Hydro. Attachments: 44C Mower and QA36A Snow Thrower. |
So I finally pieced the blower all together. I ended up with a 34" 5L belt. It tightened up okay, but towards the bottom of the adjustment so I have a 33" on order as I expect the 34" belt to stretch a little once put under load and I may run out of adjustment.
I swapped the pulley out to a quality cast iron 3.5" 5L. I soaked the old stamped steel pulley for two days with PB Blaster and it still turned into a pretzel when using the 3 jaw puller to take it off, but it came. I also took the opportunity to try improving the performance by fastening pieces of truck mudflap to the throwing portion of the auger to reduce/eliminate the gap of the auger to the drum/shell. This coupled with the speed up pulley should hopefully really throw some snow. Added 260 lb of wheel weights (had them made out of 1.5" thick steel and I had a couple lifting weights too) to a Xtrememotorworks weight bar. I fixed the head/taillight wiring too (it was all jacked up). Pics of the progress: ![]() ![]() ![]() ![]() ![]()
Looks like to me you need a longer lift rod....
Yes I do, but what I have will have to work for now. I've been ordering too many tractor parts and the wife is becoming suspicious.
But those tractor parts get her out of the driveway
