Old 12-16-2015, 01:57 PM
There are 2 different arms. One for a SGT and one for a GT. Not narrow and wide frames.
Old 12-18-2015, 01:31 PM
1811woody's Avatar
Woody, what are you talking about???? Wide and narrow frames using different arm? The frame is the same width at the rear no matter what machine.... and they didn't install Cat 0 hitches on narrow frames. That didn't come about until the 982. It was the first CC with a Cat 0. Are we talking about the same things??
CC-03-200 look this up on extreme motor works this is the info I was basing my info from
Old 12-18-2015, 04:05 PM
Yes. That is a hitch than Aaron at xtreme designed and built for the narrow frames. That is not a reproduction of a Cub Cadet hitch. It is custom made.
It says that in the description: "New Category 0 - 3 Point lift system. Complete kit. Never produced before!!!"
Old 12-18-2015, 04:42 PM
1811woody's Avatar
Yep like I said "special"
Old 12-18-2015, 08:09 PM
But you understand don't you that the narrow frame custom made 3ph uses the same arms as the factory produced GT hitch right? There are still only 2 different arms offered by xtreme. The GT and SGT.
Old 12-20-2015, 05:53 PM
PeterJ PeterJ is offline
I would like to be able to convert my sleeve hitch to a 3 point of sorts so if I come across a implement that is a 3 point that I cant live without I'm able to use it. The dimension to the outside of the sleeve hitch is 14.25. According to the info I've read a cat 0 is 20 inches so I'm looking at the cc-03-006 lift arms does anybody have a set they can measure and tell me what the offset is of these arms so I know if it is enough offset to give me the needed 20"
I just brought the 1863 with the 3-point home. If you want me to take some measurements pm me your number and I'll call you.
PeterJ
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 12-20-2015, 07:47 PM
1811woody's Avatar
Thank you for the offer, I may do that next weekend. I saw your post on your 1863 congrats.
Old 12-20-2015, 09:08 PM
red56turbo's Avatar
Woody,
Do you live in the Quadcities? If so, you're welcome to run up to my place and take some measurements/pics. I've got a 3 point on my 782D and another laying on the shelf due to go on the 1512. I live outside of DeWitt. PM me if you're interested and I can get you directions and my cell number.
Josh
Diesel Cub Cadets...........
Old 12-20-2015, 10:40 PM
1811woody's Avatar
That's great! I will do that perhaps next weekend I will pm you. Thank you.
Old 12-21-2015, 07:33 PM
red56turbo's Avatar
No problem. Just give me a holler via PM if interested.
Josh
