Old 12-31-2015, 09:28 PM
1811woody's Avatar
Jeff, Now that you've seen this view whats your take on the bracket?
Old 12-31-2015, 09:31 PM
You can either get a longer lift rod, have a piece of flat bar drilled to duplicate the hole spacing or not worry about it and go on as before.
Cheapest "fix" would be a spacer plate and sell the other lift bracket.
Old 01-02-2016, 03:43 PM
1811woody's Avatar
Thanks Jeff. I guess I didnt mention I wanted to keep it original if possible. I've done some searching on partstree and found there are 2 different lift rods but have yet to come across any dimensions. I also did some digging in my pile and came across one that was about 1inch longer but when I removed the extra white bracket it was again too short. I also noticed the mount assembly was yellow as is the slotted lift bracket but the plow is white. Did I mention this was an abortion? I did a search on past post and saw a lift bracket that is the same as the white bracket in my pic mounted on a haban plow I sure could use some imput/dimensions
from some one that has the 42" plow mounted up
Old 01-02-2016, 06:20 PM
1811woody's Avatar
Never mind guys got it figured out.
Old 01-02-2016, 07:28 PM
You gonna share with the class what you figured out?
