Old 01-09-2016, 04:33 PM
Originally Posted by mfeldmann View Post
I drained the filter seen no water. I then reused it. Can't have a new filter today. Made no difference with the blade.
The fluid in these rearend tends to trap moisture which turns the fluid to jelly, I pulled the rear cover of them and found and inch of jelly inside and that's the stuff that plugs the filter. I'm not saying the filter is the issue but until its replaced then you have no way of knowing what exactly is going on, I'd hate to see you waste alot of time and money to fix a problem that's being cause by a $5 filter.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-09-2016, 06:10 PM
What T said
Old 01-09-2016, 06:45 PM
mfeldmann mfeldmann is offline
I just changed the filter and the blade worked immediately. Since I'm selling this I'll replace the fluid so the next cub owner will enjoy them as much I do. Thanks again guys for all your help.
Old 01-09-2016, 07:01 PM
What T said
Only my mother gets to call me T.
Pap's 100
Restored 108
1211 Dual Stick
1050
Glad it worked out for you.
Pap's 100
Restored 108
1211 Dual Stick
1050
