And what are the applications for using the draft plate? Or should I ask what are the pros and cons or necessities for using the draft plate?
Are you talking about the rear plate that has the IH sticker on it? You can leave that on
Yes. I see there is a cut out in that plate that I thought would accommodate the lift pin's movement. But will have to take it off to put all the parts in? I was going to go take another look, but it is way too cold and windy.
Is the lift bar attachment already installed? ( the picture from underneath with the two 5/16-18NC bolts with arrows ). I had manual lift on my former 122 and it was a real to install that plate. By contrast, the plate on the 125 just slide right in from the back
No, none of the lift parts are on the 122. I'd start to look at it, but it's quite frigid out there. If I could fit it in my basement/work shop, I would. Can't wait to get into it. Take a wheel off? Why?
![]() See the larger holes in the fenders? That where the pin goes thru to go in the casting. |
Yes, I see that now. Can't wait to get started.
No Alvy. I'm referring to the plate that goes on the sleeve hitch before you attach an implement. It keeps the implement from drifting side to side when you tighten up the bolts.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Yes, the tin will be able to be reinstalled and will clear. The tin mounting is identical between the 122 and the 125. The only difference is the mounting holes for the optional rear light.
