That would work but no cars are not close enough.
1862, 400 tiller, brinly 10'' plow 1282 |
Olds And Zippy have battery heated jackets--wrap one around the engine?
Do you have any cans of sterno like they use for heating food? If you do put a couple under the engine. You may have to remove a battery from a car and lug it to the tractor to jump it. Other than that I think your screwed.
i am not sure why you need to heat up a gas engine. i have a cub loboy 154 that has a S/G and it started here the other day at -15 and its a pile of crap. are people sure their tractors dont need tune ups or something? do they just not turn over or turning and just wont fire? the only time ive ever had a car or anything not start because of cold is because it was in a poor state of tune. any slight issue with carb and ignition parts will be greatly amplified in the cold. heck my 1st gen cummins will start at -5 without being plugged in.
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Mine turns over just very slow so I don't know if its engine issues or hydrolic issues.
I may get flack for this but you could try some carb/brake cleaner or just dump a little gas down the carb to give it a quick initial kick if you really need it. Not the best thing to do but it works in a pinch.
-Ryan
It's gotta be able to crank (relatively) quickly to fire. Borrow the battery from the car & jump it. Otherwise grab your shovel.
Why didn't you address the hard starting before it was an emergency?
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
I had starting fluid but it's spinning to slow.
yeah could be the hydro slowing stuff down i guess. i would try to rob a good battery from something and hook up jumper cables
A relatively quick and easy thing to do is check your grounds. Remove, make sure they're clean, and put 'em back together. If it's still cranking slow then I'd bet your battery is tired. If you have time, take it (and a car battery or whatever) inside to warm it up. Batteries always work better when warm. At this point, every little bit helps.
-Ryan
