Old 02-07-2016, 10:01 AM
MWShaw's Avatar
MWShaw MWShaw is offline
I run used radials on my utility trailer.
My big 5th has trailer tires load range "E".
The only issue with running automotive / light truck tires on a trailer is side wall stiffness.
Trailer tire side walls are stiffer to help reduce sway and resist a blow out if you "curb" it, on an inside turn.
I ran light truck tires on this;
Usually between 5 and 7k #s loaded.
Hauled it thousands of miles, without issue.
Old 02-07-2016, 10:32 AM
Terry C's Avatar
Terry C Terry C is offline
I use a tire design for a trailer. I also have a spare tire on my trailer in case I have a problem. Make sure the tire you buy can handle (load rating) you intend to haul. Info is on the sidewall.
Most passenger car tires have less support in the sidewalls than a tire design for trailers. Buying used passenger car take offs is a no-no in my book. You do not what kind of life they had in the past plus there life span has expired.
X2! They passed a law here in IA that your trailer has to have trailer tires. There was a reason for it.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-07-2016, 12:15 PM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
Agreed. Trailer tires are for trailers, like motorcycle tires are for motorcycles. Yes there are darksiders out there that run car tires on their baggers, but they are crazy and cheap. They also are under the incorrect perception that car tires can work on a bike. Whatever. See where I'm going here?
I use Goodyear Marathons Load Range E. ST 175/80R13. Hell of a tire.
Old 02-07-2016, 02:16 PM
bocephus1991's Avatar
We used to run 10 ply on our goosenecks, didn't have to worry about to many flats! I ran 10 plys on my old truck, rode like a log wagon but no flats!
Brian
Old 02-07-2016, 06:05 PM
Billy-O's Avatar
Billy-O Billy-O is online now
That's all I would do for a trailer....trailer tires. I'm happy with the Carlisle "Radial Trail" for my single axle trailer. I've curbed them more than I can care to count and no problems knock on wood.
Plow blade
#2 Cart
QA36 snowthower
Old 02-07-2016, 07:59 PM
With it being a 14" tire, you won't be able to get a 10PR. Probably a nice 6PR will be about the heaviest you can get. On a single axle, I don't really have much of a recommendation other than DO get a trailer tire. They will hold up a lot better than a car or truck tire. I'm not a "small" trailer guy. The only trailer I own right now is a 16,000# tandem. I run 10PR tires on it. You just aren't going to get too many choices in a 14" tire.
Old 02-08-2016, 06:34 AM
Thanks guys! I bought the trailer new back in 2005 so the originals didn't do to bad and I have had the trailer everywhere.
Old 02-08-2016, 10:08 AM
mortten mortten is offline
I bought a used car dolly that needed tires. The only thing my tire guy would sell me was trailer tires.
Old 02-08-2016, 11:32 AM
I stopped using radials and went back to bias ply tires on my trailers a few years ago, there are times when my trailers set for long periods of time between uses, radial tires seem to develop flat spots after setting, then they come apart going down the road. That's an aggravation that I really don't need.
