Old 02-08-2016, 12:33 PM
Nice 982, Todd! Looking forward to your updates! Gotta love the 982's!
Old 02-08-2016, 12:43 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Well, here's the next one I drug out of the old chicken barn. A 1984 CCC built 984(982). A 984 has the rear lift and PTO but not the front ports.
Attachment 72051
This one is in pretty good shape with a little over 1000 hours on the meter......but the Onan is locked up.
Attachment 72052 Attachment 72053
I pulled the motor and broke out the pressure washer. She cleaned up pretty good and the original paint should buff out nice...I hope.
Attachment 72054
Wheeled her into the shop to pull the rear and do all the normal stuff. Here is a shot of the rear pto.
Attachment 72055
The rear looked good and the Hytran did its job. Just a little bit of gel on the bottom. This one will get Hytran put back in it.
Attachment 72056
Check this out. The brake hub is cracked and the aluminum caliper mount is broke in half. I'm pulling the axles to replace the seals and drill the drain holes so I will see if I can weld the hub.
Attachment 72057 Attachment 72058
Todd, I had a couple of those aluminum caliper brackets break in the exact same way, with the crack radiating from the point were the casting is angled to go around the tube. It was always one side and not the other. I found that the side that WAS NOT cracking had a spacer washer between the strap and the bracket. I think the part number is 736-3010. I went to my dealer got them under warranty along with a new bracket and problem was solved. Must have been a Monday build. The dealer and I theorized that without the washer, there was too much force on the inside of the bracket when the bolts were tightened down and bent the strap to mate on the surface of the bracket. I don't know if the 982 uses them as well but it was worth a shot.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 02-08-2016, 08:10 PM
Very nice Todd! Looking forward to your progress!
Old 02-08-2016, 10:23 PM
Thanks guys. I'm not sure what happened to the caliper mount or hub. Nothing else looks damaged on the machine and every bolt was super tight with some type of retaining compound on it. I'll look into what Frank said about the washers. I noticed some washers fell off when I removed the bolts with the impact wrench but didn't notice where they came from. Good thinking John, I will check the axles when I get it put back together to see if they are bent.
The engine....I have a diesel and a extra fuel tank but I can't do that to a 982 so the Onan that I'm doing in the engine section will be going into this one. It is a P220 which is not the correct one but close enough. I stopped by the machine shop Friday and he said I need to go 20 over on the pistons and 20 under on the rods. I need to get those ordered so he can finish his work up.
I didn't pull the B48G apart yet to see what it needs but I have another loaded 982 that needs an engine so I'm hoping I can have this one rebuilt for that 982.
I stopped by my dealer and picked up the rear gaskets and rag joints on Friday. Sunday before the game I cleaned the rear up for reassembly. I still need to drill the drain holes for the axles.
Old 02-08-2016, 11:08 PM
I've not even seen where you can buy oversize pistons for the old Onan's. Then again, I never really, really looked either.
Very nice score Todd! Congrats!
Old 02-08-2016, 11:26 PM
I was thinking they were a little much but then I pulled up some Mag parts and felt a little better...not much.
Ouch...
http://onanparts.com/index.php?main_...products_id=36
China junk?
http://www.ebay.com/itm/REPLACES-ONA...gAAMXQVT9S6SL6
Rods, anyone buy here before? Same guy on Ebay with the pistons.
http://www.gphope.com/store/1665
Old 02-08-2016, 11:37 PM
john hall's Avatar
Can you bore and sleeve it back to standard, assuming you have a good set of pistons?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-21-2016, 10:49 AM
gt383mag's Avatar
gt383mag gt383mag is offline
hey OAK would you be so kind as to measure the diameters of those rear pto pulleys the clutch pulley and the driven pulley ... pretty please when you have a few minutes
Old 02-21-2016, 10:57 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
I have bought parts from Gary's and most were real Onan parts
Old 03-20-2016, 09:52 AM
Work = Busy / Cub repair = slow
I did get the hood buffed out and I'm happy how it looks. I'm hoping I can save the paint and keep that part original.
I relined the brakes and painted them up.
I did put and indicator on the axles as John talked about and they were okay but the brake disc I welded was warped and got replaced.
I also put a set of rear braces on it while it's apart.
