Old 02-14-2016, 09:40 PM
john hall's Avatar
Looks like alum to me. Wouldn't want to weld it. Wouldn't even want to try to put a steel sleeve over it. I'd find a new one, steel or alum. Or have one made. I don't know how large the dia is but I did make one once that went on a 382 Cadet transmission. Cost of matl would be the only drawback to making one.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-14-2016, 09:45 PM
Originally Posted by V30crewcab View Post
that appears to be aluminum to me. Need to get someone to tig weld it and you'd probably be good to go.
I wouldn't fix it for myself let alone somebody else. It cracked directly in line with the keyway.
IF it were to be welded, it would most likely shrink both the bore and the keyway requiring machining. It would be cheaper and safer to purchase a new pulley.
Old 02-14-2016, 10:11 PM
I think using an aluminum pulley in this application is a bad idea to begin with. There is just too much vibration and shock for alum to to hold up.
My sickle isn't here so I can't look, but I believe all of the pulleys are the heavy stamped sheet metal ones.
Old 02-14-2016, 10:15 PM
Yes you are correct.
Up to 534 and counting...
Old 02-15-2016, 07:40 PM
knoxy_14 knoxy_14 is offline
where would i be able to find one? i havent taken it off to take measurements yet but something like this do i have to find something on ebay or is it just kind of a standard pulley?
1967 cub cadet 125
Cub cadet 102
cub cadet 71
Old 02-15-2016, 08:19 PM
McMaster Carr
Old 02-15-2016, 08:21 PM
john hall's Avatar
Lots of options with pulleys. Not familiar with the Haban sickles, is it possible new ones are available from them or Cadet? Otherwise start looking at Mcmaster Carr, Motion Industries, or anyone that sells power transmission stuff. There is a line of make your own pulleys and sprockets available, I know Shoup Manufacturing sells them, also think I have seen them at Tractor Supply. Also, you can possibly get a pulley with a blank bore and then get a machine shop to bore it, install a key and setscrew. To me your next step is to get the bore and key size, pulley OD and the amount of hub offset and overall hub length. You may not be able to get exact pulley dia, but I expect you can come close.
Here is a link to a random build your own at Shoup
hub
http://www.shoupparts.com/X10000R/
pulley
http://www.shoupparts.com/P60X/
Here is a random pulley page at Mcmaster
http://www.mcmaster.com/#v-belt-pulleys/=1154g8q
Word of caution if you buy a pulley with a machinable bore, not every machine shop has pulley taps or tap extensions so that they can install the tapped hole. You need to talk to who would do the machine work or this could get real expensive real quick.
2072 w/60" Haban
Old 02-15-2016, 08:28 PM
I'm pretty sure that isn't a factory pulley and therefore I don't know if it would be exactly like the one that should be there.
Finding out the spec's of the original would be my first priority, then go on a hunt for it.
I don't know that you will be able to find it at your local hardware store, but it shouldn't be too hard to come up with.
McMaster Carr may have what you need and I would guess a thousand other places on the net as well. Might even find one at Surplus Center for much less than other places.
Good Luck.
Old 02-15-2016, 08:29 PM
hey thanks bunches guys lots of help when the weather gets little nicer im going to take it off and do some measuring and get one ordered
1967 cub cadet 125
Cub cadet 102
cub cadet 71
Old 02-16-2016, 08:58 AM
spudder spudder is offline
I just measured the pulley on my Haban Sickle. It's stamped steel. The outside diameter is 6 1/8".
So you need a 6 inch stamped steel pulley.
I bought a 1864, it's just grown from there. The Cubs have replaced old Chevys as my hobby/passion. The only car I have left is a '67 Chevelle wagon.
Seems like a good trade off. I can put five Cubs where one car sat and there are no titles or license to fool with!
