Old 05-09-2010, 10:45 AM
IHinIN IHinIN is offline
Welcome Dave
Old 05-09-2010, 03:43 PM
Dave,
Old 05-09-2010, 09:54 PM
Shorty123 Shorty123 is offline
Originally Posted by T-Mo View Post
We're not too far apart - 120 miles.
On the PTO thing, the pto tension can be adjusted by the turnbuckle on the rod from the lever to the pto assembly. Maybe it needs more adjustment?
Darndest thing. I adjusted the button to spring plate clearance with the turnbuckle to the recomended .015. Nothing changed. Put it in the garage last night and let it set.
Got up this morning, started the tractor to pull it out and the PTO was disengaged.
Backed out, activated the PTO, shut it of......back and forth about six times. Now it is working fine. Makes no sense to me! LOL. I'll keep an eye on it and keep you guys posted.
Now I'm off to learn about sleeve hitches & rear implements for the 123. I found a sleeve hitch & rod connector to fit it. I guess I really need to find a manual first to know how to install it etc.
Old 05-09-2010, 10:02 PM
Originally Posted by cadetfarmer View Post
Hi Dave;
I am over in Rolla Mo. 100 miles west of St. Louis.
I've got a "64" 100 and a "66" 102, and would like to have a 123.
Welcome, Welcome, Welcome
from Cadet Farmer
I found another 123 Cadet Farmer if you want, here is the link.
http://stlouis.craigslist.org/grd/1705352396.html
Old 05-10-2010, 08:35 AM
T-Mo's Avatar
T-Mo T-Mo is offline
You will find service and operator's manuals in the Technical Library section on this forum.
Old 05-10-2010, 07:27 PM
Thanks! I'll look for more specific info. I rechecked it when I got home tonight. It is still working fine.
Old 05-16-2010, 12:01 PM
bgerlt bgerlt is offline
Welcome Dave,
I'm in Central MO.
I have had that issue before with about the same results as you experienced.
I believe it is caused by the plates sticking together from sitting too long.
