Old 02-28-2016, 11:29 PM
gdheck's Avatar
gdheck gdheck is offline
I meant what kind of crimper. That size of wire and connector requires a heavier duty crimper than I have.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 02-28-2016, 11:47 PM
Berwil's Avatar
Berwil Berwil is offline
Ya, you need a special crimper the size of lopers. If the automotive places let you down, I would try an electrical supply store or a welding supply store, they should have everything to make the cables.
Bill
Old 02-29-2016, 12:01 AM
Then you need to buy one the right size.
I kind of thought that would be an obvious thing.......
Old 02-29-2016, 12:14 AM
The last one's I did I slid shrink tube up the wire then soldered the ends on and took a chisel and hammer to "crimp". Slid the shrink tube down, done deal...
I ain't buying a crimp tool for the little bit I would use it. Just to make sure everything was tight, put one end in the vise and visegrip on the other and pulled, going nowhere...
Old 02-29-2016, 07:03 AM
twoton twoton is offline
This is the one that I bought;
http://www.amazon.com/dp/B000MKIQ1S/...I2UR9A46TEFMW9
I buy my cable at the local marine supply house, pre tinned cable and ends.
Old 02-29-2016, 07:33 AM
johns cubs's Avatar
johns cubs johns cubs is offline
The motorhome I pulled the engine out of yesterday has batt cables ran from one end to the other and back again. So I will be stripping it all out and saving it to build new cables. Harbor Freight has a nice ratcheting crimper for around 10$. I bought one and its built better than alot of their other stuff. If need be I can post a pic. Hammer and punch/dull chisell will work just as well as long as your not too heavy handed.
John
Old 02-29-2016, 08:27 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I use a hammer and punch to crimp the big stuff too just fine.
Before I solder though.
Old 02-29-2016, 12:51 PM
gdheck's Avatar
Found a place that has both pre-made cables to fit our applications and they have a hydraulic crimper that isn't too high priced. I think I'll just order some cables for now, after I have verified the length and hole size for my 982.
Pos battery cable
Neg battery cable
Old 02-29-2016, 01:03 PM
I think your making this way more complicated than necessary.
It's just cable and wire ends. Sold anywhere where parts are sold. If you don't have a crimper, like the guys said, pliers, vice, hammer and punch.... shoot, most NAPA stores will make them for you if necessary. Plus, if all else fails, most all are still available from CCC.
Old 02-29-2016, 01:09 PM
When I make battery cables I just go to the local stereo shop and buy the heavy guage wire by the foot, they also have the proper ends there as well.
Pap's 100
Restored 108
1211 Dual Stick
1050
