Old 06-09-2022, 05:42 PM
Farmall450's Avatar
Originally Posted by RoseHillFarmIHCC125 View Post
Wow I didn’t know you were supposed to start in the center of your garden then work your way out by always turning right. Most YouTube videos they just plow the first furrow, then back up and put the tires in the furrow then repeat.
They're doing that because of the small size. Doing a few acre field with an antique tractor, you'd do the loops and end up with 2x dead furrows on the edges of the field.
Old 06-09-2022, 06:34 PM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
Ahhh gotcha. Makes sense.
Old 06-09-2022, 08:10 PM
I have a #2 on a 1450 to do all my tilling plus customers in the spring.
Old 06-09-2022, 11:25 PM
Farmall450's Avatar
How do you quote tilling jobs?
Old 06-10-2022, 07:05 AM
By size. Most small town jobs are $35-$40, I can drive a few blocks to those.
Most out of town jobs are $45-50 as I must load & haul the rig and there are only a couple of those each spring.
Hardly anyone gardens any more, I only do about 10 each spring and only 3 of them are serious about it.
When I was a kid, every vacant lot in town was a garden and I knew most everyone!
Now, I barely know who is living on the next block and no one "neighbors" anymore.
Small town life has sure changed since I was a kid in the 50's, early 60's
Plus I offer to fall plow at no charge but no takers so far
People in general are lazy any more......sad.
Old 06-10-2022, 12:20 PM
Farmall450's Avatar
Yeah, it's a different world. Sounds like you're basically doing it to use your equipment, and they barely cover gas and your time.
