Old 04-04-2016, 04:47 PM
You don't get off that easy, we expect a report on the results. Also we insist on pics of said tractor.
Old 04-04-2016, 05:45 PM
YUP....we want to see pictures of your tractor and a report on what you find.
Old 04-06-2016, 06:12 PM
Henrykitten Henrykitten is offline
Report and pictures as soon as possible. Thanks again for the advice, drain down and filter at the weekend.
Old 05-01-2016, 02:39 PM
Default water in transmission
Thank you for your previous replies. Life has got in the way until today but I have now removed the rear cover plate from the transmission. When I removed the lower bolts 1/2 a pint of water came out followed by the oil so you were correct with your answer. I now need to know what would be the best way to proceed. The casing has a nice coating of emulsified oil which I assume has to be removed and I have to find a gasket and refill with hi-trans oil which it would seem is as rare as hens teeth over here. Is there an equivalent oil?
