From the looks of the pulley, it looks like the original pulley of the deck. I could be wrong tho
I have a with a 44a deck, I believe it is original to the tractor.
If the deck is original to the a 1450 I think it should be a model 44A deck and will use a 1/2" wide belt. The top of the center pulley measures 4-1/4" across the top. Randell, was there a 44 deck prior to the 44A? I believe the quietline came out with the 44A and 50A decks, then the 82 series came out with the "C" decks. The "C" decks used the 5/8" wide belts. Please correct me if I am wrong, but that is what I think to be accurate.
Gary 1974 1650 50A "budscub" Was my fathers 1969 125 42" 1978 1450 44A dual hydraulics 1984 782 50C dual hydraulics, waiting for vanguard Z-force Cub cadet Zero turn Sears '66 Suburban 10 Sears '66 Suburban 12 2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow 74 "Green 100 "John"
Wow! That ain't posta be that way...
That pulley is ho-made.
Now that we have established you have a modified home made pulley, you have two options.
(A) Use the existing pulley. Measure the distance around the the belt route with string and find a belt that will work for this application. or (B) Change the Center Drive Pulley to: IH-126393-C1. With that change, you will need belt: IH-117465-C1.
Just an opinion, but I would opt to change the pulley, as it has a small wrap @ that diameter and might slip under heavy grass conditions.
With that said, your smaller pulley @ 3.5" mathematically should use a 1-1/2" shorter belt than a 4-1/2" pulley would use. ( approx)
Looking at the Mower Deck more closely, someone added a plate under the center pulley that isn't original either. See attachment...
Yeah it looks like my grandfather made this plate to keep it brief from getting inside where the belt is. That's my guess
