Old 04-26-2016, 02:16 PM
gdheck's Avatar
gdheck gdheck is offline
A lot of the supers have the power steering column and a screen on the frame. That isn't much of a problem.
Something else to mention is, don't pull the screen out of the radiator with the engine running. Suction from the fan holds all that stuff on the screen and the vibration of the engine helps shake it off as you pull it out of the track. Then it goes right into the radiator. Wonder how I found that one out?
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 04-26-2016, 07:59 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Good tip!! I wonder what model I should look for the frame screen that clears the power steering?
Jay
Proud owner of the following:
Old 04-28-2016, 03:33 PM
gdheck's Avatar
1872 or 2072 should work.
#9255T765 at McMaster Carr is the stuff the screen is made out of. I think I may go with a screen that has smaller holes, to keep stuff out a little better. I think it should be alright, since air can get in the screens on the side panels and through the dash.
Old 04-28-2016, 05:46 PM
jaynjeep's Avatar
Thank you for the info!
Jay
