Old 05-20-2017, 12:17 AM
Originally Posted by oneart6478 View Post
My 1440 is doing exactly the same thing but my stalling issue does not have a time table attached to it like yours, mine only stalls when I stop hard in forward or reverse, and, as you stated, sometimes I can recover it with a choke pull but sometimes not. Then the engine may or may not start on the next try, my 1440 starts when it wants to.!!!! Any suggestions? I have blown out the fuel lines with the line at the fuel pump disconnected and put inside of a coffee filter with a hose clamp on it so I could see if any trash was in the line. New fuel pump, cleaned carb, changed fuel filter... nothing seems to be working
dvogtvpe, you mention "the anti back fire valve on the carb" where is that located?
How big a boy are you??
You sure your rump isn't coming off the seat enough to disengage the seat switch? Or maybe it's going bad?
Does this only happen when you have the PTO on? If so, I'd be checking the seat switch.
Old 05-20-2017, 07:16 AM
john hall's Avatar
Honest truth, dealer dad worked for had a small fellow running a 82 series (I think) for a municipality or school. Anyway, mower kept cutting out/off/missing so they brought it in. Mechanic mowed for forever, couldn't make it act up. Carried it back, unloaded it, and before the driver made it back to the dealership, customer called in, same problem. Long story short the guy didn't weigh enough to keep the seat switch tripped when he hit a bump.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Tags
2135, fuel, stalling
