Old 05-04-2016, 08:11 PM
Yesterday
Mowed grass
added oil (got a 80-20 engine. burns 80% gasoline 20% oil)
Added air in front tires.
It was a good day.
Old 05-05-2016, 06:12 PM
Not technically a cub but I finally remembered to bring home an impact so I could get the blade off my IH push mower so I could finally get the engine apart, the bottom crank bushing is worn out and the crank moves around.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-05-2016, 07:59 PM
Good work Tim!
Old 05-21-2016, 10:11 PM
Pulled the blades off the zero turn and turned them around. The boy sharpened the blades last week and got them on upside down. I am sure it looked right from underneath!!
I did get on the Original and drive around the shop. Just because!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 06-29-2016, 09:25 PM
I pulled the fenders off the 1211 so I can access the leaking auto valve and to make room to install the dual hydrualics.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-29-2016, 09:38 PM
Very nice Tim, looking good!
Old 06-30-2016, 09:05 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Pulled the broken engine mount bolt out of the 1200.
Put wing nut on my 149 air filter, the PO had a nut on there.
Ordered a new spark plug, wire, air filter and fuel line for the 149. Also found a muffler mount / heat shield online and ordered it.
Still looking for a pressure line.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 07-02-2016, 04:41 PM
sbd-3's Avatar
sbd-3 sbd-3 is offline
I took the blower off the 125
Then i changed the oil in it
The 38" deck is on and we mowed.....
Jerry
72,106,107x2,125,126,127x2,147x2,149x2,1200
Old 07-03-2016, 11:31 AM
Good looking 125!
Old 07-03-2016, 12:20 PM
RedOnes's Avatar
RedOnes RedOnes is offline
I saw the snow blower mounted ..hopefully wont need that for a while
..but since you`re in Indiana , anything is possible ..
Frank
IH 982 , 3 point
CCC 782
