Old 06-12-2016, 09:54 AM
twoton twoton is offline
Not that one,basically the disconnect on a 1450 is adding a gear drive clutch to a hydro.
A factory option, or owner mod...?
Old 06-12-2016, 10:02 AM
Factory option.
Up to 534 and counting...
Old 06-12-2016, 10:04 AM
As a cold start assist?
Old 06-12-2016, 10:06 AM
yes indeedy
Old 06-12-2016, 10:08 AM
What a concept!
Old 06-12-2016, 10:23 AM
Originally Posted by twoton View Post
Yosemite Sam, Are you suggesting that this could be the source of the vibration?
So I guess if the front PTO bearings were bad that could be a source of the vibration. If so, you could get some new bearings like this;
http://www.onlycubcadets.net/forum/s...572#post369572
and rebuild it like this;
http://www.onlycubcadets.net/forum/s...746#post191746
Old 06-12-2016, 05:29 PM
Dostuki Dostuki is offline
It looks like there is a missing bolt here. Upon closer inspection, there is no hole to simply replace the bolt, as if the bolt head had sheared off at some point. I cant imagine what would have made that happen.
I have a terrible video I made of it running that I will post later today. Thanks everyone for the replies so far.
Old 06-12-2016, 05:43 PM
https://youtu.be/taG2gJ2Nlqs
Here is a short video of it running. Like I said its a terrible video, but it shows some things like the driveshaft and the vibration that you can hear.
Old 06-12-2016, 08:27 PM
Put the flashlight to it, and the bolt head is sheared off. Should be fun to get that out.
Old 06-12-2016, 11:22 PM
bocephus1991's Avatar
Pull the engine and remove tha pan, easier than fighting with it.
Brian
