Old 06-17-2016, 05:15 PM
Do the 2 or 3000 series shaft. Easy to do since you have the ability to do a little fab work. They are also pretty cheap to buy from the sponsors or rweaver. Best way is to stick the shaft in a lathe, cut the weld then cut the shaft to the proper length and re-weld it. You already have the proper adapters so all you need is a complete drive shaft with the fan. Just be careful with the measurements between the back of the engine and the pump adapter. That gives you the assembled total length of the shaft.
Old 06-17-2016, 06:07 PM
Darrell Darrell is offline
Terry , I have a driveshaft like that you can have if you want it , but that is all there is , just the shaft. It came from a 2185.
Not sure how to ship though , i guess a cardboard tube if i can find one long enough ??
SIX SIX ZERO 841 5647
