Old 05-18-2010, 06:18 AM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
I am 6'1"and weigh about 265#. I had my AG's on last winter on my 1200 and the first storm was ready to push the world with it. I was sadly disappointed as it wanted to spin like a mad man. What it did for me was just get stuck then bore down as the lugs kept digging. My AG's(10.50's) are loaded with antifreeze and have about 50# of weights on each wheel too. I then replaced the AG's with my 8.50 turfs that are loaded with antifreeze and like most said,no comparison. It really performed exceptional. Now I have the AG's on for mowing and they really help out since my yard is soggy and wet usually. I spun like crazy whan I had the unloaded and unchained turfs on last fall..
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 05-18-2010, 08:23 PM
Well, I guess I'm a lone wolf on this one. I put True Power Ag's on my 123 with weights and did fine in the winter for the most part. If I slipped, then I put my chains on the Ags and had no problem at all. My tires aren't loaded, but with a little help from my buddy Jack, the driver is!!!:biggrin2.gif: I know guys that will switch tires around if they have problems. Really, experience is the best teacher.....just find out what works best for you in your situation.
Old 05-19-2010, 01:32 AM
nix1650's Avatar
nix1650 nix1650 is offline
I am with you. I had no problems last year with my 1650 or 1250 with about 50lbs hanging off the back.
Old 05-19-2010, 01:49 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
I too had no problems with my ag tires. As they all said, each situation is different. Up hill, down hill, ice, no ice. I've spun on ice with turfs and chians. I've marked up blacktop driveways with them too. Over all, I like my ags. Try not to put so much air in them. Let them squat quite a bit. More surface area on the ground.
