Old 07-24-2016, 03:38 PM
dodge trucker dodge trucker is offline
I just got a nice 50" deck shell like that yesterday/ pitted but solid. I have a 44" version that is beyond "shot" that I want to swap the spindles and such over to (Yeah I know that I will need that I will need a new set of blades to go with the 50....) I need to either find, or make, a reinforcement plate for it.
Old 07-24-2016, 04:52 PM
Terry C's Avatar
Terry C Terry C is offline
Please report on how your 1200 handles that deck. I've never used a 50 on
anything less than 18hp. I know it will work but just want your opinion.
I think Jmech has one but his engines are well tuned.
The deck looks nice by the way.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-24-2016, 05:25 PM
mortten mortten is offline
I have a 50 on my 1250 and have never had a problem as far as power goes.
Old 07-24-2016, 10:33 PM
samiam44 samiam44 is offline
Does the faster pulley work on a 50 inch deck or should I get a new 79 inch belt?
M
Old 07-24-2016, 11:43 PM
Came out good
Did you forget to replace the runner on the left side?
Old 07-24-2016, 11:45 PM
I do have a speed up pulley on it and gator blades. The pulley is NLA. The gators seem to make the clippings smaller. The pulley seems to throw the clippings a little further than the standard.
Old 07-25-2016, 10:27 AM
Originally Posted by jaynjeep View Post
Looks Really Good!!
Have you tried McMaster Carr for the stainless carriage bolts? Or a local bolt supply house.... probably wont find them just anywhere
Thanks jaynjeep. I have seen the carriage bolts online. I have not checked all the local hardware stores yet, might get lucky. This coming weekend I hunt them down. Thanks, TB
Old 07-26-2016, 11:42 PM
A friend of mine has a 1200 and a 1250, he had the 50 on the 1250 and the 44 on the 1200.... his 1250 had no problem running the50.
remember today's (actually the last 15-20 years) "HP" is nothing like "HP" was when these tractors were current production..... remember something about newer engines.... stickers are cheap. IDK how B&S can get anywhere from 14 to 18HP out of an opposed twin with the same bore/stroke.... the 18 is probably a truer 14HP....
Old 07-27-2016, 03:11 PM
Came out good
It is broke off. Someday I will have to weld a new one on. I just couldnt stand the rust anymore and felt the need to paint it.
The 1200 seems to handle the 50" with no problems. Sometimes I do have to slow down if the grass is too thick, like most other mowers, but the 12 hp seems to power it ok. Thanks, TB
Old 08-07-2016, 06:20 PM
Howdy folks. Here is an update on the deck project. Got the top plate primed and painted with three coats. Got the rear hangers primed and painted. got the spindles primed and painted. The previous owner had replaced the right spindle with a newer style spindle, it seems to work fine and cut even, although I may search for an original at some point. I replaced the idler pulley as it was seizing up. I did not order a "cub" idler by part number, but instead found an exmark idler with the same dimensions. All I needed to do was to press out the 5/8 to 3/8 adapter (with a shoulder), and press it into the new pulley I did find all the carriage bolts I needed in stainless as well as all the other bolts. It is all back together with the relatively new blades sharpened. All that is left now is to get it dirty, then see how it cleans up after use. Here is a few pics. Thanks, TB
