One more thing, the 1914 has 3 toggle switches. One is on the right side of the access panel. It has to be activated first before the mower deck pto switch will work. Also the same switch on right side access panel has to be activated before left toggle switch on access panel for rear pto to work. Are 1772's with rear pto have toggle switches in access panel also or, are the toggle switches mounted in the steering tower where the fuses would be? Are 982's toggles mounted like the 1914 in access panel?
why do you have to change the rear end ? Just change the rear cover .
Adrian 2072 (789513) |
My 1772 has no fuses in the steering tower just 2 holes. Is that where the toggle switches are supposed to go originally on a1772 or are they in the access cover like the 1914?
Access cover??? No idea what you mean. Post a pic.
I too am disappointed your going to part up a 1914. You understand they are rare right?? |
I'm having second thoughts about removing pto and 3pt from 1914. Going with ruegge 3pt still need to know where rear pto switch is mounted on an original 1772 with rear pto.
I don't understand why this is so difficult to figure out.....
All you need to do is take a minute to actually research the machine. http://www.cubcadet.com/equipment/AR...0-A/0029400018 |
heres my 1572
I'm new to this site, still having trouble navigating through. Thank you all, for your help.
