you have it out ,I would do the cork gasket now .
I'll second that--cheap parts and you have already committed to most of the labor. Even if that is not the leak, those gaskets don't last forever.
Cork gasket on the way, from looking at it up close before cleaning it looks like a possibility, and right, not a lot of $$.
Is it my imagination or is the gasket installed with the self adhesive on the axle, holes in the gasket on the top half so that the 3 holes in the axle are covered up?? Thanks! |
IIRC, the 3 holes are not used on the aluminum rears. On the CI rears the bottom hole is an oil drain and the other 2 for the alignment pins.
Oak is right, but the early hydros had bolts that hold the removable swash plate to the case inside, and on the later ones, the swash was cast in the case so the bolts and holes for them were not needed.
They just make one gasket to cover all applications. ![]() |
As the others have said the early hydros had 2 bolts for the swash plate and a case drain hole. Late style do not have the bolts and the case drains back through the bearing. I install the cork gasket up side down on the later style so that the 3 holes are covered they I put a dab of silicone in the holes of the gasket. Pic shows where I locate the gasket with the red circles.
That's the way they are on both of the ones I have disassembled, sounds like good advice Sam.
Really appreciate it guys. |
I thought someone mentioned on this forum some time back that a newer style gasket was available that was not made out of cork......
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
