Old 08-08-2016, 07:03 AM
I wouldn't replace those. Just grease them and run as is. The wheels I had listed are for the older style Haban, you have the late style.
Old 08-08-2016, 09:58 PM
stevescub stevescub is offline
The rubber is thin and aged looking for fronts, and right rear is separating, so when I allow wheels to ride ground it causes scalping. PO had set up rear at higher point so front lower, thus took most of weight and no scalping.
Old 08-08-2016, 10:26 PM
Dirty Steve's Avatar
Oak has a part number for the front wheels. He recently shared it with me. Can' t remember the number but they are the same as a 290 deck front wheel. I think. Maybe Oak will be along to help out to help.
Old 08-08-2016, 10:36 PM
734-3195A
Google the part number. Instead of $70 from Cub you can find them for $40 or so on the interweb.
Old 08-09-2016, 09:49 PM
Default rear caster wheel assm for 2182 60" haban
thank you Dirty steve. So far my luck googling for items has been dismal. According to my search on cub sites, i believe NLA. Will try some more surfing tonight.; Done some surfng and found for $45 front whl assmb, but not found rear- only part number so far i found ha-20252. What , where/what is a 734-# for rear wheels that might provide me more info. caster whl assm. is 8 x 2.5 and a 3" hub lg i believe from measuring?? May have to re check?
Old 08-10-2016, 04:14 AM
Unless the bearing is toast on one or both of your rear wheels, I also would not bother replacing those. But if you have to these might be good ones:
http://apollocaster.com/product_list...=&search_type=
http://apollocaster.com/store/8-x-21...2-p-89912.html
Old 08-10-2016, 04:19 AM
Or these.
https://www.motionindustries.com/pro...p?sku=02544724
Old 08-10-2016, 09:53 PM
Thank you very much. These two sites never showed up in searching for under various terms-- rubber on iron caster wheels, rubber caster wheels, etc.
Bearings are good but rubber deteriorating, esp right rear separating, and rubber thin on both fronts.
