Old 08-02-2016, 09:27 PM
Originally Posted by jays375 View Post
Right now my 1010 is stuck in reverse or first.What is odd is that you can still put it into 2 or third.
It is a 1000.
Well.... if your sure, I'd say the odds are about 3:1.
That's a guess....
Odds are kind of irrelevant though. Take the fenders and tunnel cover off. Then remove the top of the trans. Chances are the ball in the shift tower is broken, and it slid into a gear, then you lifted the gear shift lever out of the shift rail and down into 2/3. Your going to have to manually put it back in neutral, and repair the shift tower. Welding will be required...... if that's what happened. You'll know when you take the cover off. If you don't, then post a pic of the inside of the trans.
