Old 08-04-2016, 08:58 PM
You don't have all the right parts. That second yoke in front of the square shaft is a quick couple end for a regular PTO. You don't need it. You need one that will weld onto the shaft. The splined shaft is stuck in the yoke backwards in your pic. No machining should be required at all. Should all be weld together.
You will need a weld on yoke for the square shaft. Make sure to get one that you can attach a guard to, or it won't be like OEM.
