Old 08-05-2016, 09:37 PM
Ok I looked, no JQ shaft,I am assuming you do not had a JQ shaft ?
Old 08-05-2016, 09:45 PM
Lew
I used the short shaft box from a 1440 and the upper shaft but removed the CV joint for the tilt steering. I cut the upper shaft and welded it to the Woodward coupler then added a section of tube to make it the length that I wanted.
Old 08-05-2016, 09:53 PM
Sam,
I cut the shaft down on the long steering box from a 1810.It had bad threads on top any way,Then I cut the tube,then I filed,yes filed,the two flat spots on it then drilled a hole for the retaining bolt,came out just like the original one I needed.
Old 08-05-2016, 11:15 PM
Originally Posted by Tim.E View Post
Thanks guys,for the replies. I actually do have a tilt type steering gear from a (I think) 1641. I believe I can make it work by attaching the top of the tilt extension in a fixed position. By the way,do all CCC 3 turn steering gears have the tilt feature,or are there some fixed,solid shaft types ?If so,what tractors were they used on?
What about 982's,what type steering gear did they have?
I have about 5 or 6 "super steer* axles,so need to accumulate 5 or 6
3 turn steering gears.
Another reason for using the JD steering from 110,112,212,214,etc is, they are non-tilt making for an easier install.
So,does anyone know for a fact that the JD 3 turn worm gear shaft will fit in the CC 2 turn housing?
Here is a picture of one of my tractors with a super steer axle ,still using the original CC 2 turn steering gear.
Nice tractor, Tim! I like it!
Old 08-12-2016, 09:03 PM
Tim, which models did these super steer axles come out of? Would using one help me out on a 149 I plan to put a loader on?
Thanks, Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 08-13-2016, 01:28 PM
V30crewcab V30crewcab is offline
I got a busted 1440 box if anyone needs the 3turn gear for parts.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-19-2016, 12:10 AM
Tim.E's Avatar
Tim.E Tim.E is offline
Randy, I believe they were on 1440,1541,1641,1863,1864,maybe others.
V30,I might be interested in the shaft/worm gear.Is it a tilt? pm me.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 08-21-2016, 06:54 PM
Thanks Tim!!
Randy
1 100's
2 149's
1 73
1 2182
