Old 08-10-2016, 08:04 PM
Is it boiling?
put a thermometer in the rad to see if it is indeed too hot.
Have you garden hose flushed the block passages when you had the freeze plugs out? ----and the head?
Is there a noticeable drop in coolant temp comparing the bottom hose to the top hose??
I'd go here next if you haven't been here. IR guns come in handy for this.
Or, you could just loosen the radiator pressure cap and see if the engine boils over and matches the gauge at the boiling point.
Old 08-10-2016, 08:13 PM
FWIW:
I have an IR gun and while it works mostly ok but I don't trust it as some surfaces
give erroneous readings.
Old 08-10-2016, 08:19 PM
FWIW:
The IR guns will read differently depending on the color or shine level of what you aim it at, there not very accurate.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-10-2016, 08:29 PM
On the other hand, if you take the radiator cap off, you're at sea level, the barometric pressure is XXX and it doesn't boil over and the gauge shows maybe 220*-230*, it gives an indication the gauge is wrong.
That is why I mentioned an alternate checking method.
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I've learned to use the ir guns over the years and generally do trust them on a head. Still eat a few grains of salt now and again.
What kind of gauge is on this tractor? And are you absolutely sure its overheating? Check the head temp near the sender too!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-10-2016, 09:03 PM
it has a mechanical gauge, both the old and new gauge said it was to hot.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-10-2016, 09:10 PM
While we all are throwing out ideas, check where the gauge thermo bulb lives,-- sometimes there gets to be a deposit build up in the cavity insulating the gauge bulb from the coolant, just something else to check tomorrow.
Some engine design leaves something to be desired, I'm assuming it is in the head rather in the block.
Old 08-10-2016, 09:18 PM
yes, its in the rear of the head.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-10-2016, 09:37 PM
Is there another location where you could put it to see if it duplicates the readings?
Old 08-10-2016, 10:09 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
radiator cap hold pressure?
correct psi cap on it?
was it a new radiator or just a cleaned up unit?
have you checked for combustion in the cooling system?
have you done a bubble test to the cooling system?
are there any other coolers in front of the radiator or in the radiator that could be causing heat to raise the coolant temp?
