Old 09-03-2016, 09:05 AM
mortten mortten is offline
Yes. That bushing should be pushed down into the tube. If it won't stay in you can use a punch and dimple the tube to keep it in. Since you have it apart look to make sure the hole in the bushing isn't wollowed out. You can also use a 3/4" front wheel bearing in its place.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 09-26-2016, 06:35 PM
duckpin duckpin is offline
Just wanted to update this. Took off the wheel and indeed the bushing was pushed down the steering column. Put in a couple of washers and it seems to be just fine. Thanks one and all. Now on to the next problem ...
Oct. 1968 IH CC 105
Broyhill water sprayer
Peco "20" lawn vacuum
No. 2 trailer
And hoping for more!
Old 09-26-2016, 08:11 PM
I have a 104 that that bushing won't stay down in place. I drilled a hole through the column tube and into the plastic then ran a small screw into the plastic. It doesn't move now.
