Old 06-04-2010, 12:43 AM
Lmercer Lmercer is offline
Originally Posted by wig View Post
one spring return and one float return. 4-1/2" wide by 6" tall and 2" thick. Very small compact just like cub cadet used with same bolt pattern to mount to tractor. Made by cessna.
Would this mount up to a 1650? I've been thinking about adding front hydraulics to mine
Old 06-04-2010, 07:40 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
google Log splitter parts. You can get a 4 way cheap. That's what I'm using, but not with a loader.
I'm doing a lift, then two lines to the rear, and kwik fittings for a piston on the dump trailer.
Fly Fishing is not a sport...It's a way of life.
Old 06-04-2010, 08:44 PM
IHinIN IHinIN is offline
I found a valve today. It's the same as the one wig has. It came off a JD 317. Got it for $50.
Old 06-07-2010, 12:03 AM
Nice find! So, it has ports for 2,3, or 4 hydraulics?
Old 06-07-2010, 06:23 AM
It's a 2 spool valve. One spool has a float position and will be used for the lift so that the deck, front blade, and 3 point can float. The other spool will be plumbed to quick connects at the front and rear for an angle cylinder for the front blade and possibly a dump cylinder for my carry-all.
Old 06-07-2010, 09:19 PM
wig wig is offline
yes mine will mount to your 1650. That is what I bought it for before I came across my 782 with duals. Good luck finding one that is that cheap and compact.
